OK here she is whach the vidio and special thanks
First of all HAPPY X MASS TO EVeryone
and and a round of aplause to everyone who has helped me on my little mini over the last 6 months Hey fellas it was worth the work what a fastastic fealing I LOVE IT :D :D :D :D :D Its my firsst one and im hooked this is a x mass to remember hay olfart i beffed up my prop got rid of the 2*4 ahahahaha warp drive awsome . Ok a Hudge THANKS to everyone i hope you like the vid
would love some feedback WHAT ya All think about my FLYING FROG
:shock: Happy x mass to all
here is a link tio youtube
:arrow: /www.youtube.com/watch?v=RuKTbZ81g00
now all the new mini guys on here got someting to shoot for . good job man bet there will be a full sized boat in your future the fever will not go away 8)
IS THAT ONE OF THE LAKE BUGGY BOAT? I WANT TO BUILD A MINI FOR FROGGING .I WAS THINKING ONE OF THOSE 10' BABY GILO HULL WITH A 25 HP BRIGGS MOTOR WITH A BELT REDUCTION .HOW DO YOU MAKE THE BELT REDUCTION?
FlyinFrog, I couldn't be happier for you ........ that little boat runs real pretty. Fantastic, man! Be careful and have fun!
olf
Yep, looks like you got the right set up for sure. Have you taken a GPS to see how fast she runs with just you on it? Looks like its riding really good and layed down. Does she jump up on a plane pretty easy? And give some specs about the running gear. Thanx for the video and good luck with everything. Cajun
I had to freeze-frame it as the boat passed to see this... COOL steering stick. I like the way it's bent and takes advantage of a triangle being a strong shape. And the way it's mounted with the hinge point well BEHIND the driver - puts it at a very interesting angle.
Looks comfortable to grab.
I'm surprised there are not more boats with that set-up.
VERY NICE BOAT!!!
That is the best mini I've seen on here. Nice work. Especially with that little French engine.
Mood, if you look in his gallery you will see he moved his seat forward and modified the stick to accommodate the move. He left the pivot point where is was and bent the stick. Good work.
Very Nice mini you got there.What kinda of prop is that? How much pitch are you running? With my 440 I can only run 7 Degs. Will it get on plane in deep water with 2 guys.
Thanks for the kind words and sorry for not answering i just cant seam to get of de BOAT
Moody ' yes it is a lake plan boat for 2 people modified .
about reduction drive how to
RPM Motor maxed 6000 rpm
So motor lasts 3000 normal running
main shaft pulley diam 190
Pully to prop Diam 200 So
3000 * 90 /200=2850 prop speed rpm
So rpms motor multiply by pulley main shaft diam then devide by the pully to prop diam this should give you prop speed i used alum pullys A tey say 1 belt for every 10 hp
Josh The prop im using is a WArp drive 60` 4 prp but i am using only 2 i have it set at 6 degrees cannot plane in deep with 2 together we wiegh 230 kgs hahaha water have to run in from shallow no problem then with the gps with both of us 30 km solo 35 kms
:D
