I just got this boat 3 days ago. The boat had been sitting for around 5 years with out running. This is every thing that I have done to it
changed the carb to a new Qjet that had been sitting in the shed for a year
New plugs cap rotor
new fuel filter oil and filter
cleaned gas tank out the guy said he had drained gas before parking it and he had put new gas in it. I drained that gas out (looked like tea) and put new gas in it.
I got the engine running good would start right and idle and spin a 67" prop up to 2900rpms at 1/4 throttle (he had a 80"x 34 pith wood prop on it but it was bad from sitting)
I went to take the boat for a ride but it was to wind so I didn't put the boat in the water, on the way back home it started raining really hard.I didn't have the air breather on the carb. when I got home I covered the carb.
The next day I tryed to start it and took awhile to get it running and now it only running on 3 cylinders. 2 on one side and 1 on the other. I checked this by putting water on the header while it was running.
I have changed the plugs again.Made sure that there was no water in the cap. I"m running off a different gas tank now also. It running rich and back fireing out the exhaust. I don't know what else to check. also It seems to run a little better if I take the vacuum line off the distributor and plug the hose. Thanks for any help Josh
New plugs cap rotor
