NorthWestFloridaBoy
I wanna buy a used airboat in the next year or so but I need some help figuring out what would be best for my needs. We don't have a lot of sawgrassy areas up here like in the glades, mostly rivers (15+ feet deep) and brackish bays that can get pretty choppy at times. I like the idea of the deckover so no water can swamp me like the open hull. Is an aluminum deckover lighter than a fiberglass open hull? What are the pros & cons of riveted vs. welded, will one hold up to pounding chop better than the other? I want it to be about a 12 or 14 by 8 with a 4 cyl aircraft engine to keep it light and stable, no need to run dry trails or start on mud flats like you guys. does a 4cyl ac motor weigh less than a 350 dd? if so how much because if it is close the 350 dd might be a better value due to low cost. how about a 4.3 dd would that work ok in open water? we have a lot of logs and stumps in our rivers would the alluminum hold up better than glass, I assume i won't need poly. Any thing else I might be overlooking? Oh yeah I almost forgot, does anyone want to trade a 12 foot deckover with engine for a 2006 yamaha kodiak 4x4 with dual winches and mud tires? Thanks for any info fellas.
