Pacemaker
Well, I'll say the system is great, Darin is top notch at customer service, if having it installed be 100% sure who installs it, attention to fine details, true top dead center for one, setting the pickup coil at that point, the correct layout of the remaining reluctor pins.
I have it on my io540 and also put it on my brothers io520 we love it, cold starts or hot starts . no problem, customer service is top notch.
A little birdie told me that even if you only have 5 volts in the battery, switch off roll it through each cylinder compression cycle by hand, get it to just before TDC#1, switch on, pull prop through and it will fire up.
DISCLAIMER:
NOW THIS I PERSONALLY HAVE NOT TRIED, AND IF YOU HAVE NO KNOWLEDGE OF HAND PROP STARTING AN ENGINE !!!!DO NOT ATTEMPT THIS!!!!
