patching steel flex
bondsman
on patching steel flex bps said" if you are lucky you can slide off your boat on the trailor and do the repair" on another post. my question is what brush you would use and will it run heavy if boat is angled and not upside down.or is it just as easy as brush it set it back on the trailor let dry and go.
Just did it three days ago. I used a foam roller and the boat was on the trailer, I just slid it to one side. Is it perfectly smooth? No, but then you can kind of figure that out before you start. It seems to be doing fine. I ran the boat for about four or five hours today. I figure it'll do until I'm ready to re-do the whole thing.
