The story with this boat is he was running it (using lots of oil), and one day the motor locked up on him. After investigation, Blake found the cylinder to be cracked and a ring was frose on the piston in that cylinder. So, he sent them away and got one new cylinder and the others reworked. Ran it for approximately 10 hours and the motor still using lots of oil, and he is hearing a ping sound. Decides to pull the jugs again and found a bad piston again. Not sure what was wrong. Now my question, since he has 10:1 compression, would the gas he is using cause this problem? Or does anyone know another reason? He is using 93 octane. If I hear more of a story, I will let you know, but this is all I know right now. And Dean, this is Blakes boat, so if you know more, feel free to post. Thanks, Brent
