AlaskaTours
Hi all,
Instead of two seperate posts I'll combine the two.
First question is I'm trying to get more push out of my boat with 5 people in it on the river I have to skip over sand bars to get it up on step . I'm running a 350 small block, gear reduction (belt) 3 blade 76 inch WhirlWind not sure what type blade I do not see it listed on the web site It is set at 16. What are my options ? I was told I should run the 2 blade 76 Stump puller and my problems should be solved , What do you guys think ? Airboaters are far and few up here so I can not get any good info beacause not as many of us up here as there are down there.
2nd question is pitch could I adjust my pitch on the prop I have now to give me more push ? If so How does pitch work ? Red Neck terms please.......
, I'm not a very ebujacated man... :shock:
I did learn a trick from a fellow airboater up here that I'll share with you ,You might allready know this trick . But go to you local Home Depot buy a carpenters level Sit it on top of your blade get a reading than put it on the end of the blade at the tip on the angle of the blade and you will have your pitch do the same to all your blades keeping the top number on the blade the same all the way around .That way they will be exact no guessing and it's quick. I keep one in the boat
Here is a few photos
