Current poly on a glass hull, I can probably reuse a lot of my bolts, question is, was it done correctly? They countersunk big pan phillip head bolts so the head of the bolt was flush with the polysurface.
Anything wrong with going back the same way. Seems like a much less drag issue that way.
1/4 on the boat now, going to 3/8 instead unless someone tells me different.
Jeff
Jeff
