poly on a glades style deck over
moose
boat had slick bottom it's a 7' 12" aircraftaluminum would like to put poly on.
would it be to heavy for it with a 220 gpu ? would a 11' sheet be ideal?very light weight boat.shallow,not sure if i should put poly or more slick bottom on ,i do have a hard time keeping it in the river if you know what i mean...
i've had 3 grassboats 2 with and 1 without i have to say i like the poly. be sure you get a good coat of steel flex prior to application of poly.
I run polymer on mine. Does slow ya down a bit. Still fast enough to hurt you.
Grant
KR23":o1h9znrh said:
........ be sure you get a good coat of steel flex prior to application of poly.
I never heard of putting Steel Flex first then the poly. Is this something new being tried. Care to share some secrets??
Scotty :?: :idea: :idea: :?:
Wow, I never heard of that. Makes sense though, Do you do salt water operations mostly? Not arguing just old bears learn slow sometimes.
Scotty
Mostly fresh ...coastal Louisiana marsh for alligator eggs. Had aboat with poly on the sides no steelflex...lots of corrosion five years later....never do that again. Good paint might work as well though.
Grant
Grant, no personal experience with this, but I've heard that you can also paint on a thin coat of roofing cement (the black, gooey stuff) and that when you then sink the screws or rivets it seals them as well as protects the bottom.
olf
Sounds like it would work. Might give it a try. Have used contact cement when capping worn out hull...just anything to stretch its usefull working life a little past prime!
Grant
It might be a little messy, but clean up wouldn't probably be more than a little acetone on a rag. A guy from up in this area told me about it, and said that they sometimes used 1/4" poly on their aluminum crabin' boats because of oyster bars.
just as grant said to stop corrosion, but i have only run the glades not any salt water. i have friends with boats from thurman, don, and war daddy and they all have steelflex under the poly.and these guys have been building boats for years so i guess they have been doing it this way for awile. don't really know.
This is my first post in your forums and I must also say that y'all have an excellent site here. I heard about it because my wife (Michelle) works with Dawn and Sondra.
Anyways....
Couldn't help but to respond to this post and it may be a little lengthy to explain...I am in the industrial coatings business and what you are experiencing with your aluminum corrosion is due to a process called Galvanic Corrosion or Dissimilar Metal Corrosion. It happens when 2 different metals are in contact with each other and one sacrifices itself for the other. Zinc being the most sacrificial metal there is (hence the zinc on a boat motor to protect carbon steel parts) and Graphite and Platinum being the least sacrificial. If you are using Stainless Steel bolts to attach the poly and that bolt comes in contact with the Aluminum, the Aluminum will sacrifice itself for the Stainless. There is a triangle that must be present for this to happen 1) the metal join must be wet with a conductive liquid 2) there must be metal to metal contact 3) the metals must have sufficiently different potentials. Salt water is the worse because it is more conductive. Water travels up the threads and to the contact area and that is when corrosion takes place. Even morning dew can do this. As the water evaporates it becomes more concentrated and corrosion speeds up. All you will need to do is seal the exposed areas (top and bottom) with something like clear polyurethane, clear nail polish after the area is completely dry.
I don't know anything about the Steelflex you are referring to, but if it seals the water from getting to the metal contact point, that's why it is working.
Sorry to be so long winded. Hope this helps.
EVERY BUILDER AND AIRBOATER IN SOUTH FLORIDA THAT'S INSTALLING NEW POLYMER PUTS A NEW COAT OF STEEL-FLEX DOWN 1ST , IT KEEPS THE MOISTURE OUT FROM IN-BETWEEN THE ALUMINUM AND POLY AND SEALS , MOST EVERY ONE DOWN HERE USE'S COUNTER-SUNK AIRCRAFT RIVITS NOT SCREWS OR BOLTS.... INSTEAD OF PAINT WE USALLY MATCH UP THE COLOR OF STEEL FLEX WITH OUR BOATS AND ROLL IT ON THE SIDES AND TRANSOM OF THE HULL IN-STEAD OF PAINT ..STEEL-FLEX IS ALOT MORE DURABLE AND SEAL'S BETTER THEN PAINT.... HELL STEEL-FLEX IS A CURE ALL I HAD A E-185 WITH A LEAKY OIL PAN , I USED TO STEEL-FLEX IT ONCE A YEAR AND NEVER LEAKED AGAIN....LOL
D-BREWSTER, I HAVE TWO NEIGHBORS MIKE STOSSEL AND AL DAVID WHO BOTH HAVE BUILT NICE DECKOVER BOATS.THEY BOTH USE THAT SAME METHOD OF STEEL FLEX THEN POLYMER AND BOTH BOATS RUN REAL WELL IN AND OUT OF THE WATER.
GENEVA , ITS A SMALL WORLD BROTHER , YOU TELL OLD AIRBOAT AL YOU MET DUSTY BREWSTER.. ME AND AL HAVE BEEN FRIENDS A LONG TIME , WEVE WORKED ON BOATS AND BUGGY'S TOGETHER HUNTED AND PARTY'ED MORE THEN A TIME OR TWO THATS FOR DAMN SURE.. YA AL BUILDS A REAL NICE GLADES STYLE FULL DECK HULL AND DOES A BAD ASS CAMO PATTEREN ON THEM.. IVE HELPED AL ON A COUPLE BOATS IN THE ACREAGE DOWN IN PALM BEACH BEFORE WE BOTH MOVED , I WENT TO NORTH FLORIDA AND I HEARD HE MOVED TO THE ST.JHONS..IM BACK HOME NOW AND ID LIKE TO GET IN TOUCH WITH HIM , NEXT TIME YOU SEE HIM TELL'EM I SAID WHATS UP AND GIVE HIM MY NEXTEL IF YOU DONT MIND , I WOULD DAMN SURE APPRECIATE IT BROTHER...159*138357*2, IVE MET MIKE STOSSEL A FEW TIMES BUT I KNOW HIS BROTHERS BOYD AND ROBERT ALOT BETTER....GOOD TALKING WITH YA MAN......LATER
HERES A PIC OF ME AND AL AT MIAMI CANAL ON OUR BUGGY'S , RIGHT AFTER THAT I BOUGHT HIS RICE AND CANE'S FOR MY RIG...THAT PURPLE RIG HE BUILT WAS A BADD ASS BUGGY , I KNOW HE HAS TO MISS THAT OLE GAL..
DUSTY,AL'S NEXTEL # IS 157*174*6250 IAM SURE HE WOULD BE GLAD TO HEAR FROM YA.WE ALSO HAVE MIKE {MERT} STEVENS LIVING HERE. HE IS A GOOD FRIEND OF THEIRS ALSO FROM WPB. THIS AREA WE LIVE IN HAS BECOME AN AIRBOAT COMMUNITY. YOU SHOULD COME UP SOMETIME AND RUN WITH US.LOTS OF NICE DEER,HOGS,TURKEY,AND GATORS.AL'S PROPERTY BACK'S RIGHT UP TO GOPHER SLOUGH ON LAKE HARNEY.SOMETIMES WE RUN RIGHT FROM HIS BACK YARD TOTHE SLOUGH.
GENEVA -I DAMN SURE APRECIATE THAT , ME AND AL GOT TO CATCH UP AND BULLSHIT.. ILL BE UP THERE IN THE NEXT COUPLE WEEKENDS TO SEE HIM , WHATS YOUR NAME BROTHER I WOULD SURE LIKE TO THANK YOU IN PERSON...OLD MERT'S UP THERE TO ? DAM I GUESS I GOTTA MOVE UP THERE IT SOUND'S LIKE A NEIGHBORHOOD FOR RETIRED SOUTH FLORIDA OUTLAWS !!
