Polymer
calbrigsr
Several questions! 1. Where can I find polymer 84"wide? 2. If you splice it how do like the splice? The bottom of my boat at the transim is 84" wide. I have a 13'6" hull. What kind of polymer do you feel is the best as far as longevity and slickness?
Tivar 100 UHMW or Durapro is what I use . Poly Hi Solidur is the company that makes it . You can get it up to 96" wide and as long as you want . Comes in 1/4 3/8 and 1/2" thick .
I have ran it for several years on a couple of different boats , on dry ground , gravel & rocks , pavement.... you name it ! Wears great .
There are several distributors in Fl .
Laird Plastics - 4 locations - http://www.lairdplastics.com or 1-800-610-1016
TPI Tampa 1-800-283-1200
Hope this helps , Good Luck !
Hey Chuck,
I have sample from Horns plastic and they can make it all the way to 120" I 'll come by and show you what I got from them.
Geoff
