Brownitsdown said:
. . . my question is being it’s a step hull does lowering the rear of motor push my bow down?
Also don’t have much room to lower rear of motor and no I don’t want a trim tab
In spite of some things being different with a step hull,
the generality of lowering the rear of the engine to lower the bow does in fact, remain the same.
If it is not possible to lower the rear, raising the front will accomplish the same thing, if that is the easier implemented option.
Needless to say, there are other parameters (other than engine attitude) that could be responsible.
In this particular case, to much weight aft is also be something that could maybe held suspect.
Generally, starting with the easiest corrections first will ultimately simplify the process.
Despite there not being any other option in some cases, I do agree with you about the
desirability of a trim tab, as they are analogous to treating the symptom rather than the cause of the problem.
