Power Output
islander
Active member
what kind of power can i expect from a Cotinental 0470 GPU converted to aircraft with dual mags and 520 jugs and fuel injection?
Thanks,
Sam
islander,
give gpu rick a call 352-595-1943, he be able to answer your question, he's also on this site.
jeff
250 t0 300 depending on piston and timing and how much you shave the case and the cam grind call tom jeffords he can tell ya what you need to know
what do u think the average fuel burn be on the 520 IF the case was not shaved,stock gpu cam with carb two v holley? i know alot of issues such as hull weight,design and so on would factor in, mainly somebody that has done this on a hull that was 220 and converted to 520 would chime in.
4 to 5 gal. per hr. depending on how hard you run it.
