POWERSHIFT HUB / SENSENICH BLADES ????
CRACKERSTYLE
I have a 74" powershift 2 blade prop for aircraft and a 70" sensenich 2 blade for aircraft. I wanted to swap blades in different hubs. I put the power shift blades in the (short) sensnich hub and wala It works great. I put the sensnich blades in the power shift hub (long) and they dont fit? It seems the sensnich blades are a little bit fatter.
Is it b-cuz I have the old style powershift hub?
I thought sensnich and water walker hubs/blades were interchangable?
So whats the bottom line is it ok to put sensnich blades in the old style power shift hub? There seems to be about a 1/4 inch gab between both hub pieces. When I dont swap blades there is about enough room to slide a piece of paper in between.
Just wanna be safe
thanx
