M mwood7800 Well-known member Apr 4, 2006 #1 If someone is using a 2 BLADE SIGNITURE SERIES on there 540, what pitch or setting are you using.
L Larry Moderator Apr 4, 2006 #2 My buddy is running a 74" signature on a angle valve 540. He is running at right on the reference mark and it turns up right at 2900rpm. Larry
O ONA540 Active member Apr 4, 2006 #3 I'm running a lycoming straight valve (260), 74" power shift turning 2900-2950 on the water. I used an angle finder from home depot, I can't remember what degrees it was, but I will measure and report back
B Buck Thruster Well-known member Apr 4, 2006 #4 We set my friends straight valve 540 72" Signature Series right on the factory marks. It turns 2900 rpm.
D duckluv26 Well-known member Apr 5, 2006 #5 same here, 0540 SV set on the reference mark, 2900. make it easy and set the reference mark dead center of the hub and plate the first time.
