D dannix48 Active member Oct 3, 2007 #1 On my small block ford (302) I'm running a 68x36 wide blade. Would it be better to run a 72x30 stick prop? Thanks for any help you guys give me!!! :?
A AirCat Member Oct 21, 2007 #2 dannix48":315m0009 said: On my small block ford (302) I'm running a 68x36 wide blade. Would it be better to run a 72x30 stick prop? Thanks for any help you guys give me!!! :? Click to expand... Is there room enough in the cage to spin the 72 and have at least 2-3" clearance? Are you operating at optimal rpm's now? Check this site for some tech input: http://www.hoverhawk.com/propspd.html
