Outlawaircraftengines
I figured maybe you guys know what prop I need. I have a 4 blade narrow 80 inch on about 4 1/2. Its past the 3 mark and around the (F) where the prop says flat head screws. I called Sensenich and they can't believe a 540 can turn a prop that hard. I turn it about 2600 on 7 lbs of boost and 3300 plus when I ran it up to 14 lbs. It seems like it is too much prop on the bottom before the turbos take over and not enough on the top. Would the wider "Q" series blades work any better. If I could pitch them around 3, I should increase bottom end performance and hopefully the wider blades will put a heavier load on the turbos. Any suggestions?
