sarros2004
Active member
Hi All,
Need some help. Not sure if I have an engine issue or prop.
I finally have my rig mostly assembled and in the testing phase now, Thanks largely to a post I previously had here and all of your valued input.
Here is what we got. I am running a 14 ft Airgator, 2.38 rotator, and an 80 inch 3 blade R prop. The power plant an LS2 6.0 aluminum block running a standalone ecm with fuel injection. It also has an upgraded cam, and long tube headers. I am estimating the hsp conservatively around 500.
I have been told the sweet spot on this prop is 2200-2400 rpms which with the reduction is have should put the engine around 5200-5600.
Our testing has been on dry ground, as ultimately the intent is to get in the sweet spot to get it moving on the dry before we hit the water.
The our first attempt we had the prop pitched at the 2 mark. We couldn't get over 3100 engine rpms. We backed down the pitch all the way to 1 over gradual adjustments finally achieving around 3700 engine rpms.
We gave up on that and switched to a 2 blade hub, using the same 80 OA blades. Again we started pitch at 2, and achieved an rpms in the 4000 range. We backed the 2 blade pitch down to 1, and got around 5000 rpms, just on the cusp of wanting to make the boat move.
I have read many of these forums, and received many suggestions. I do not feel I have a bad prop, gearbox, motor ratio. It just strikes me as odd that I appear to be ha ing so much trouble getting the prop to turn. Leading me to believe that I may have an engine issue. It runs well and sounds strong.
Not sure what I need to ask here, just looking for some input and some advice.
