Just wondering! You have gas tanks and radiators blocking airflow, and propellers below transom height. That propeller blade hitting the point where there is not a clean airflow will back off, probably back off an inch for about three feet untill it picks up clean air again. I know how it works because at 40 below we run what many of us call "Ukrainian thermostats" on our vehicles. Chunk of cardboard with a hole to allow some air through, you can hear and see when things are not centered. It's just a 19" fan blade but the same thing would happen with a airboat prop. So how much more thrust could you get if you cleaned things up? I think the AC Deckover guys have the biggest advantage in this respect. How many airplanes you see with tons of stuff in the radius of the prop? I just think it should be a cosideration! 8)
