Super Snapper AB300 72" airboat propeller
FROM WHIRL WIND
IM STILL OLDSCHOOL I RECKON IVE ALWAYS RUN WOOD PROPS , BUT THERES GOT TO BE SOME ADVANTAGES OF THESE 3 BLADES , IM BUILDING A NEW BOAT AND WANT THE BEST PERFORMANCE PROP THAT'S TESTED TRIED AND TRUE FOR IT .
MY LAST MOTOR WAS A (0-470-B 240 HP @ 2600 R.P.M. ANGLE VALVE) AND IT DID REAL GOOD WITH A 72X36 WIDE BLADE WOOD PROP...
MY NEW MOTOR IS A (IO-470-S ) IT WAS 260 HP @ 2625 R.P.M. WITH THE STRAIGHT VALVE CYLINDERS ), IT WAS JUST CONVERTED TO ANGLE VALVE CYLINDERS WITH 8.6:1 PISTONS IM HOPING FOR AT LEAST 15 TO 20 MORE HORSE OR BETTER SO SHE SHOULD BE AT LEAST 275 HP NOW )
IVE ALWAYS BEEN LEARY OF THE ADJUSTBLE PROPS AND ALL THE POWER SHIFT STORIES HAVENT EASED MY MIND NONE , IM LOOKING FOR ADVISE FROM YOU PROP DEALERS AND 1 ST HAND STORIES FROM YOU GUY'S THAT RUN THEM..... THANKS ALOT GUY'S ALL COMMENTS ARE APRECIATED ....
FROM WHIRL WIND
