I was doubtful about those shrouds, but at least one person (Duckhunter ?) from LA that posts here has one from Marks. Mark and Duck ?? said the same thing, they drop temperatures on the cylinders about 100 degrees. That would be something to really consider if you were running 93 octane and follow what Big Daddy said. You should stay out of trouble doing that.
For around $120.00 you can get a cylinder head bayonet attachment, wire lead, and a cylinder head gauge from Chief Aircraft. You can play around and fine out which cylinder is your hot one and leave it mounted on that cylinder. Or if you know someone with one of the Temperature detectors that you point at something and it gives you a reading, use it to determine the hottest cylinder and go from there.
This way you could keep an eye on at least one cylinder's temperature (most the aviation guys claim one is always hotter than the others) and it would give you some satisfaction that you know what you cylinder heads are running. Jurnigan can tell you what he would consider the max CHTs should be.
