I do not have a book for that motor, But every hydraulic lifter motor that Lycoming made I know of is .028 - .078. with the lifters blead down. You should have the standard Lycoming 2 bolt intake gasket. You need to take the intake pipes off and surface the intake pipes and collars. If you have chrome intake pipes they will not be smooth. Lay the intake collar on a smooth surface,or hold two of them together bottom to bottom. You will have a big gap. Whenever I bolt an intake pipe on I hold the pipe on my belt sander and I have a tool I made to beat the collar flat. After I beat the collar flat then I surface them. They are usually bent so bad you cannot sand that much metal away. The collar has a groove cut in it that the intake pipe sits in. They make a collar with a deep groove and a shallow groove. Yours probably takes a deep groove. As far as the intake parts. All of the motors are rough castings from the factory. It seem to work for them. Some say that the roughness atomizes the air and fuel more than a smooth surface. I dont know for sure.
