c chardt
Boat runs good and rides good,But porpoises,Put a trim tab on and fixed that problem, Level the the stringers prop is hub is level.But when running fast it pushes down on nose hard enough I lift on the throtle . Even if trim tab is picked up so,Should I shim the rear of the engine up, and how much would be recommended. Only when I go fast.
