i have a don davis deckover just put 2 gallons of frogspit on about a month ago alredy close to worn off thinking of putting polymer on it would like suggetions on what thickness and the best way to apply thanks
well id say for your style hull use 1/4 or 3/8 if the hull is riveted u can take the top of the hull apart and nut and bolt it or ac rivet it if not and its welded hull use the machine screw 1"x20 is the correct sz for that screw also u can ger a self tapper in the machine screw that saves time from drilling it all out
