My last boat had poly on it and had no problem running the ground even in the middle of the heat but my question is I am thinking about going with frog spit or something like it but am not sure what to expect out of it as far as how long will i get out of it before i have to put it back on I mean i just like the idea of not drilling holes in the new hull. I will not have to worry about stepping on a bolt with bare feet if i dont witch is good but how long does this stuff last if you run the pasters and stuff. would only be running the ground where it would be just grass pasters not running gravel or anything like that. I was just hoping to maybe get 6 months out of it and if i could then i would consider it being i would only have to do it twice a year but if i have to do it every 3 months or less I am going back with poly.....Any info on this from you guys that run slick bottom or whatever would be great thanks.
Glenn
Glenn
