You can also download a app for your phone that seems to work well.
Gary turned me onto this in a post a while back. Any of the electronic levels work fine too, but only carpenters carry a level on a Airboat, everyone (that can afford a Airboat) has a phone in their pocket. My son came by today to help re-install my engine, rigging and prop. I had a good opportunity to document.
At first I let him set it, he nailed the marks on #2 first try. But then I whipped out the phone for a double check and found the pitch off by 0.9 degree. So we loosened up the bolts and added a bit of pitch to one blade with the rubber mallet without breaking the press on the blades.
First, no need to set the crankshaft level, or even a need to calibrate the level. All that matters is the difference between the readings.
First thing is to level the prop hub. Honestly, boat cocked sideways on the side of a levee, no problem. Use a 30-degree reading on the hub as long as each blade is measured on the same hub reading. In my case, it is easy to remember 0.0 degrees.
Measure Blade #1. The key is finding a way for your measuring device to find the same spot on each blade. In my case the phone itself fit's the blade tip well. You can also measure off a point from the center of the hub on each blade and lay a larger straight edge.
Rotate to the next blade, repeat setting hub to the same "Level" setting and check the next blade.
So that is as good as it get's. For reference, note the difference between the two prop hub marks. I'm not sure which one is more accurate, but the blade tips run the fastest, so since I'm trying to eliminate vibrations I gonna try it.
