Red River Airboats (mini)
  • Start date Start date
A
Anonymous
Guest
Well I guess I'm a little late to be asking for advice since I recently pulled the trigger on my new rig from Red River Airboats. I currently run a 16x52 all weld jon boat with a yamaha 50hp powerhead which equates to about a 25hp at the jet. The jet will run pretty skinny but it takes almost as much water to get up as a regular outboard and I'm tired of sucking crud up my impellar that clogs water circulation and creates overheatin issues. About a month ago a friend turned me on to these mini airboats and since then I've been doing quite a bit of research on them.
My primary use will be duck hunting (35 times a year) and maybe some floundering etc. For many years Red River has basically converted jon boats to airboats by adding the cage, engine and polymer etc. but now he has designed a mini airboat hull (100 gauge), puts 1/4" polymer on the bottom and rigs them with 45 to 85hp rotax or kawasaki engines w/ 3 bladed prop. The entire rig cage and all is aluminum. The boat is definately cheaper, quieter and lighter than the big rigs I was looking at previously.
My rig is a 14x60 (with 3" higher sides), 85hp liquid cooled kawasaki, 3 blade adjustable pitch prop, 1/4" polymer, aluminum cage and stand, grass rake, bench front seat w/storage, bow storage, nav lights, bilge pump, 2 100 watt spotlights on cage, gauges etc., a galvanized trailer. Basically it's ready to run for just a little more than what I paid for the jet rig. As I recall the hull will weigh only a few hunded pounds and I think the motor weighs like 80lbs. He's also gonna powder coat the entire hull, cage and infrastructure.
I am use to the weight issues from running the jet which is basically a 3 man & gear boat. The jet will run about 25 with this load and I hope to get at least the same from this rig with shallow water capabilities. I'm not really concerned about running absolutely dry but I expect to run very shallow tidal flats and some mud. I would be nice to be able to start and stop in these situations. Mostly I run 2 guys and gear but I must have the ability to add the third guy if necessary and I do not anticipate ever having 4 guys.
Can some of you experts let me know what you think the boat will do with the load I'll have and any input on the engine. Do you think I will be happy with the rig.
Thanks.
I had an ultalight With a Kawasaki Engine on it and it was very reliable
and I have never heard of any thing they build being Bad or having problems and I have had the Idea of a mini Airboat for some time And I think it is a great Idea and as a mater of fact Diamondback Airboats the folks that built my boat are now in the process of building that very thing a small more affordable airboat.
when you get your boat I would love to see some photo's of it.
What's the smallest horsepower airboat you've ever run and how did it perform.
Paul Dixon of AIRBOATS UNLIMITED in Bainbridge, Ga. builds the best mini airboat anywhere. They just don't get any better. He can put you a 35hp Vangard and get you 30mph and also run on the hill in grass. Try him and see the facts.
I herd a lot of bad things about red river and silver dollar airboats there kinda partner/ friends.
I also heard some bad news about both of them airboat company's. I thought they both filed bankruptcy. Make sure you get your boat before you pay them.
I have been talking to both companies lately and they are both putting new boats out. both paul dixon and bobby bogel (red river builder). The Red River boats are lighter and more powerful than Paul Dixon's boat.
How well will Bobby Bogel's new hulls run ground? What size Kawasaki would be the best to run mostly mud flat but a lil ground with two people at most?
Are the Kawasaki engines two stroke or four. I dont want to have to constantly mix gas to run my airboat.
________________________________________________
Thl ThL Smart Phone
