Cowboy, That is one fine boat Sean is selling. He said," it runs anywhere the big boats go, not as fast (who needs to go that fast anyway), and with alot less fuel." Wish I could buy it also, but I have 2 boats to get rid of first. I talked to both Sean and his dad and they said they have made some improvements on their boats over the other Palm Beach builders. Their gusseting is thicker plate and they have changed some of the design and structure of the hull. How does your Father's Kline perform, dry ground, power, responsiveness, etc.? It's probably 6061 .125 and it looks like a 220hp Continental?
Cracker, Thanks for the information. I will be investigating more about the aluminum sheet size and corrosion problems. There are quite a few aluminum builders here in LA. I saw that tensile strength info in the Kline catalog, and Hadco has it on their site. It would be nice if someone makes 7075 T-6 in 5' wide sheets, then you wouldn't have to add to the two 4' sheets to make a wider boat. When I got my boat, I installed a battery switch to help with the electrolosis. I'm also going to install a magnesium anode. Every little bit helps, I HOPE!!!!
Marshmaster Pat, Sean has a customer now that wants a 6061 boat. He is figuring up the cost and weight of the material now. He is going to use .125 6061 T-6. On a 12' boat with two 4' wide sheets, 7075 T-6 .090 weighs 62.88#'s a sheet =125.76#'s. A sheet of 6061 T-6 .125 weighs 84.7#'s, 2 sheets weigh 169.4#'s. You are only talking about 43.64#'s difference in weight using 6061, but not nearly the tensile strength of the 7075. 7075=83,000psi, 6061=45,000psi.
Sean favors an aircraft aluminum boat. He's into light weight, strength, 4 cylinders, and fresh water. He also says a 6061 T-6 hull wouldn't be nearly as strong as a 7075 hull and the sides could get dented up with the 6061 where the 7075 wouldn't. Upon hard impact, the 7075 would flex and could possibly split but not dent.
Hamant uses 6061 T-6 .125 bottom ,090 sides to build their 12'x7'6" deckover boats, and so do some of the other builders, Diamondback.
Sean likes to use the spray-can zinc chromate (Tempo makes it for outboards). He uses it at the riser cap before riveting the boat. He said if you use paint there before riveting, the rivets would crack the paint when installing them.
For maintainence, he uses Liquid Electrical Tape between the riser cap and the hull as well as on the rivets inside the boat to keep the loose rivets from leaking. He likes the way it flows and gets between the riser cap and the aluminum to create a protective seal. I'm sure there a better sealants out there then the L E Tape. I've used black 5200 with acetone to even it out.
Anyway Pat, I think a 6061 boat would be better choice for us since we use them in a salt enviroment. We just have to be careful about denting the sides. I don't want to have all the maintainence problems that come with the 7075, but I do want the responsiveness and strength. Decisions decisions decisions, I guess we can't have everything!!!!
I'll be talking to Sean about the new 6061 boat and my boat. I'll let you'll know what's happening with the new boat.
