I read some posts regarding rock boats and I was just wondering what thickness of material these guys are running! :? 20 gauge at .035" is 1.5 lbs per square foot and 12 gauge at .1046" is 4.3 lbs/sq'. A 16X8 would have about 180 sq' of sheet on it and the guys I have discussed it with just use flat bar for stringers. Have seen some jet boats are running it here in the glacial rivers. The thing is my river will have 3' of water and the boulder will be sitting 2" below the surface. Also it is a material I have a lot of experience with and would not require aquisition of more tools. How much do your finished hulls weigh? Not planning to run any brackish water so a good epoxy finish would suffice. I also think lighter material would work if you used poly. Any ROCK BOAT OWNERS out there? :wink:
