Rocker ratio's, RPM's, Gear ratio's and Props
capt. catfish
Active member
Still trying to get this Cadi squared away.
I am running a 1.73/1 Stinger and 78" 3 blade Falcon Series. Stinger says that is the wrong gear for that prop. I was wondering if I moved up a 2.38 gear and changed rocker ratio, if that might be the combination I need to make full use of this prop?
I am using the 1.62 rocker ratio now. I think that Potter Automotive offers a 1.72 rocker system that should allow me to run close to 5000 rpm,s.
Anyone outthere using a similar system? Any comments would be greatly appreciated.
CAPT ! GOT POTTERS SHAFT ROCKERS ! GOOD DEAL ! 237 BOX ! BUT YOU WILL BE AMAZED AT THE PUSH THAT LITTLE CAD WILL DO WITH THAT BOX AND PROP! ONLY PROBLEM I AM HAVING IS NOT ENOUGHT CARB ! MY SUCK IS CLOSE TO 100 PERCENT ! REALLY WORK OUT WELL ! WILL GET HOPEFULLY , BE FORE TEMP GET TOO HIGH ON MY PISTONS ! ALREADY TOASTED A MOTOR BECAUSE OF STUPIDIDY ! LACK OF LISTENING !DO THE ROCKERS FIRST AND THEN THE BOX ! YOU WILL BE VERY WELL PLEASE ! I AM VERY WELL PLEASED WITH POTTERS STUFF! HE WILL GIVE YOU THE INFO YOU WILL NEED ! HE JUST WANT TO SEE CADILLAC STUFF DO WELL ! HES A GOOD VENDER! :D
Hey Capt
Where do you have your pitch set now?
I bet you can go to the 2.37 ratio and add some pitch to your prop to keep your engine turning close to what it is now so you don't have to turn it up to 5000, and you will get better push too.
Red
Hi Red,
I hanen't any idea what the pitch is. I have the blades set to where the mark is even with the center of the hub. Prior to that setting, I measured 1/8 inch from the mark to the negative and that allowed the engine to reach 4300 or 4400 rpm,s.
I will talk to Potter tommorow about the rockers and then find someone with the proper gage and find out what the prop setting is.
Thanks for help. I will post results ASAP.
Catfish
Hey Capt.,
When you get ready to set the prop give me a call and I'll bring the digital meter to fine set it.
Bob
4200 engine rpm with your box and the prop set at the referance mark, is optimun blade push according to ps/ww.
Just talked to Buddy Branch this morning. He really likes the rocker system from Potter Automotive even though he thinks a bit pricey. Buddy says the system I have now is fine. Wednesday he is bringing a timming light, a different tachometer and we are going to do some checking to make sure everything is runnin' right.
Will get the prop set correctly soon I hope, and we'll seen how she performs.
Thanks for all the responses,
Capt. Catfish
Good morning Bob,
Would like to get this prop set. I got your DC number from Big Daddy, but if you recall you and I where unable to connect via Nextell the first time we tried. I got the same results yesterday.
If you get this message, please phone me at 813-917-7906.
Thanks very much,
Capt. Catfish
