rfox - Could you be alittle more specific?
More grief than what I can imagine on an airboat is some mightly bad $hit.
Not wanting to start anything, it is just we have some very experienced people with almost every airboat setup I have heard of. There very likely could be someone here that could give you some tips or information about what you having issues with.
I know of only two rotator gear boxes on rigs I know the operator, and one is a counter rotator.
The counter rotator is on a 454 & the seal went out. But it was apparently was just a few hours after what Panther said you could expect it to be needed to be replaced.
The other is a normal rotator is on a chevy 350 that is supposed to be making around 370-380 horses. It makes all type of noise at idle that I just cannot get used to. It has a leaking rear seal as well, but I know they over filled the gear box for quite a while. Some misunderstanding on the amount of oil to go in it. It leaks just alittle and makes a nasty mess, but they apparently are not ready to deal with changing the seal. So I am thinking the leaking seal is more an operator issue.
So what is the deal with your rig?
