Very long story made short. Boat used to run straight as an arrow for miles. Had the boat worked on to fix a power/pitch issue in the props. Now the boat pulls dangerously hard right. It’s a full on workout to keep the boat straight or even make a left turn. I have looked at other posts amd typical speaking, you should turn the tabs in the direction it pulls and that should fix the issue. Only difference I have noticed is that I run a counter rotate setup. Two sets of three blades. So Could part of my issue be related to incorrect pitch in the the first or second “set” of blades? I don’t want to bend the tabs if it’s possibly not the issue. Would be glad to explain in much more detail if need.
