Rudders Foam Filled
JTFSU3
Looking for someone to build a set of foam filled rudders in the Haines City area. Any recommendations?
:florida:
Gary it’s a gear box 0540. The hollow rudders echo noise at low rpm. The foam filled quiet things down.
I didn’t think about GTO I’ll check with them. Thanks
Gary S said:
why do you want them foam filled?
Helps the boat float when you sink😊 Seriously though, you do need a pro to foam fill them, overfill and the rudders will look like a poison pup.
That makes sense.
