As I mentioned I've got a 350 4-bolt truck block that I plan to build up. The kid that had it spun a rod within a week of building it. (You mean you have to check the pickup to pan clearance?
) It needs a crank and probably a rod. The pistons were new. I've got several set of rods and various other SBC parts sitting the garage
Here is decision #1.
Do I just buy a crank kit (or turn this one) for a couple hundred or do I spend more like $1k for a 383 rotating assembly.
I've also got 3 sets of stock iron heads. Two are off an HO camaro 305 and one set is the stock truck 350. I haven't cc'd 'em yet. If I use them I would do my standard benchtop mild port polish work and likely go to 2.02 and 1.60's
Weight and performance wise I'm probably better off buying some AL performance heads. I'm just trying to decide where to spend the money as the budget is somewhat limited.
General question, If I do a budget build on the 350 and end up with +/- 325HP can I get by with the same reduction/prop setup by just changing pitch when I upgrade later to a more robust 383?
Does that make any sense?
