Crowhater- I was asking for recomendations because DD automotive engines as used in an airboat is a subject I have no experience with, I anticipated recieving advice from people with experience in this field. It's not that I just want to spend more cash, I just figured that if there was a certain kind or style of pump that would make a better choice for my application then that's the one I want. If a stock oem style pump will work fine then so be it.
WaterThunder- I will probably buy a scat crank, I believe it has a .092 or .093 radius or something like that. as far as rods I thought about staying with the stock ones unless there is a good reason to switch to aftermarket. I didn't think rods would be a big deal due to the relative low rpm nature of the engine, If I need to use aftermarket rods with the scat crank please let me know.
Red Dwarf- As always thanks for the info.
