AirRanger
This is my new airboat. I ran it this weekend and if performed better than my expectations. It ran dry, climbed the ridge with ease, and was very smooth in deep water. Cruising speed was comfortable around 1800 RPM. At WOT it never exceeded 2500 RPM. I do not wish to change the performance but if it does improve I certainly will not complain. The prop is a 4 blade 72" Warp Drive. I am going to try a 72" Terminator only to quiet down the prop. Should I keep the RPM range where it is or would I be better to raise the RPM range a bit? Classic Aluminum w/ poly, 14'7"X 7'6", GPU 220.
