Sensenich prop
hunterboi34470
How do I know what model prop I have. Right now I just know it's a 2 blade 70" sesnsenich prop. Is there any markings on it that tell you exactly which blades they are
If you pull the prop there is a label on the end inside the hub. Call Sensinich with the serial number and they can tell you all about it. Faded isn’t an issue, but overall age is. They borescope inspect from the inside to confirm status. They rejected an old prop I had based on the scope inspection.
If you don’t want to take it off you can measure it and look at specifications on the web site. That may ID it.
Keep in mind some of the older models you may need to dig a little deeper to find their data.
