ARMYCOUNTRY43
Thinking about getting a Jimmy white square nose 13-7 putting a 0360 on it thinking of using a single rudder trying to build it like my dad in the early seventies just wondering how it would drive compared to duals
Post a pic or two, particularly the forward/prop end. It has to be rounded at the front, no break or point.... the rudder that I found is as you describe it's real thick at the back of the cage and gets narrow as it goes back and probably is the measurements that you gave I guarantee it will turn you like you said
I ain't gonna talk you out of it for sure, I love my single rudder setups. About 11:00 am, when the grass get's tall, hot and sticky, that's when these big ole rudders shineI would like to try to build one like he had back then
don't really need speed but don't want to go slow
and gigging frogs is what I plan to use the boat for I appreciate everyone's help and advice
Sounds like a 68" 2 blade is what you want for that O360. Blade width (10-12) becomes a minor choice on the same scale.I would say I'm more of a idle around thanks for the advice![]()
