slick bottom and bottom jack
josh_2562
How much does it help.I have got my mini to where it will move about 15' on dry grass with a little push. Do you think slick bottom will help get it running dry.
Bottom jack how much should I jack the bottom down. Thank for the help
I like to set the jack where the boat setting on dry ground has a little rock in it.
with out raw HP you give up water performance to run dry. Also tilting the rear of the motor up helps too, but again takes away from water performance
