Mark Bennett
Ok, I've just purchased a new 18'X8' boat with all stainless rigging and 3/8" polymer bottom with a crate 383 Stroker engine with a 2:1 belt reduction drive on it. Well, when I picked it up, I got a chance to run it for about 4 hours and the choke on the carburetor kept sticking and kept the motor flooded the whole time we were running it. We took a short look at it and decided it would be best to take it back to the dealer and let them look at it instead of us trying to fix it ourselves and messing something else up. Once we got it back to the dealer, they called GM about the problem and GM had them break the motor down and check several other things. Then, they put it back together and it was running around 100 lbs. of oil pressure. I'm still not sure what was wrong with it exactly. Finally, they ended up putting a new motor on the boat (which I was very thankful for) and calling me to come back and pick it up. When I get over there to pick it up, they inform me that I should never run the boat over 4,000 rpm's and to never haul more than 2 or 3 people in the boat. That's kind of where the problem came in. This boat is mostly used for duck hunting and we normally have 4 people to a hunting group. The 4k rpm's I might have been able to live with, although I don't understand it at all, but we always have more than 2 people. My question is, is there anything we can do to make this motor have better performance? I thought I was very specific when I explained to the dealer what the boat was going to be used for, but needless to say, I'm now stuck with a brand new boat that will not perform the way I'd like it to. Any suggestions would be appreciated.
