spark plug gap lycoming
DAVE C
Trying to remember gap for plugs on lycoming with electromotive electronic ignition ???? Thanks
diamondback0320
Ngk 2910 is the stock # & most go by the other # which is ab-6 & yes I run them...026-.028 with mags if I remember correctly & I now have the electronic pacemaker ignition which the gap should be .035
Those are non-resistor plugs. Do any of you run non-resistor on electronic ignition and have good luck with no interference on electronics (radio, dog tracking gear etc.)?
I need lower heat range plugs but don’t find any options in resistor plugs, other than adapters and smaller plugs.
