D DAVE C Well-known member Jun 26, 2019 #1 looking for spark plug size for 0540 lycoming for cht sensor they list them for 10mm 14mm and 18mm denso plugs Thanks
Slidin Gator Well-known member Jun 26, 2019 #2 18 mm spark plug threads. Note that I have found the spark plug base temp readings (using laser heat gun, not ring CHT) to be 50 to 100 Deg F less than the bayonet CHT's that Lycoming specifies.
