Spark plug swap on GPU 220
AirRanger
What difference/s if any should I expect to see? Stock GPU 220, Holley 500. Pulled Champion plugs gapped.020, installed Denso gapped .030.
Doesn't increasing the gap cause the coil in the mag to have to increase the voltage? Not sure how this affects a mag in general. It may cause the coil to possibly run hotter.
Speed Wheelie, Des Moines, Mike Thurman...I know you guys can shed some light on this.
