well I've had the boat out a couple times now ..at first it plowed really bad ..i leveled the engine to the center stringer helped immensely then talked to a guy that had a similar hull that plowed he had me bend the back of the boat up a little went home and tried to get the hook out ..little better then i moved the gas tank to the back of the boat ...water is far back on plan with no porpus untill i turn then the corner diggs and sprays my passenger. the boat has new poly and no jacks running out of things to try
