JD1":j7lt7fma said:I don't understand why you would want to put it on if your going to put poly on, but maybe I misunderstood. Mike Thurman might know the differance between the two. I thought I read somewhere that the 2000 had teflon in it. JD
THANK YOUcowboy":10b16o8o said:Yeah David.
It sure can't hurt noth'in.
Grant's advice above is good.
The regular stuff will do great for what you want.
No need for superslick.
never applied what should i do, what should i use to clean it off with thank youOlf Art":3ntbxs8n said:David, all you're lookin for is something to coat the hull between the poly and the aluminum ...... there will be moisture in there when the boat has been run and you don't want that aluminum hull to start to corrode under the poly. It's especially important for boats that are run in salt or brackish water.
A lot of things can be used, but standard steelflex should do you a good job. Don't get stingy with it, and clean the hull good before you put it on.
olf
