If you want accurate measurement, you might want to invest in a rotary vane anemometer to measure air velocities at various points behind the prop and rudders. It would be a good tool to avoid the guessing game of their placement. Spiral slipstream, or prop wash, is rotational as well. The air behind the prop twists. A wide prop with more pitch will have a greater effect than a thin blade with less pitch. That's why you can't go with a ball-park rule of thumb calculation. It may not be right for your boat.
Here's a reasonably priced unit at Grainger.
http://www.grainger.com/product/28AF77?gclid=CNrUsvP6i74CFWuhOgodlw4APA&cm_mmc=PPC:GooglePLA-_-Test%20Instruments-_-Air%20Movement-_-28AF77&ci_src=17588969&ci_sku=28AF77&ef_id=33VPG1xxWR8AAAez:20140502001539:s
Through trial and error over many years and numerous builds, older manufacturers have fine-tuned the placement of the various components on their boats. Well placed rudder height, separation, set-back and size can mean the difference between a responsive boat and one that feels like mush.
Lee & Judy did an awesome job on my Scorpion. The steering is light and neutral, is very responsive underway and pivots on its' own length at rest.
