Getting ready to replace my stringers. First time doing this.
Should I have the hull flat down on concrete, or should I have the hard edges on blocks to let the bottom set down?
The bottom should be perfectly flat front to rear correct?
The boat currently hops, and it seems to be running on its nose. I checked the bottom and it's fairly straight in the back, but might just start flexing with the rotted stringers.
