goldhunter_2
looking for suggestion to free up two stuck piston so I can pull the jugs. I have two pistons stuck big time (all others are off) I have soaked inside with PB blaster then beat on the jugs with rubber mallet , next soaked both cylinders with coke over night still can't get them free I have a good size pipe wrench I put on the prop shaft plate an next can hang my whole body's weight on it in the air an still will not free up :twisted: then I rigged some plates and hooked up a 120lbs of air to the cylinders but they will not budge
