bondsman
i bought a 2 blade 78inch sensenich superwide to go on my boat i did not want to change anything but prop. i have a 1.9 gearbox with a caddy and all i can say is 3 blades would have never worked with such a gearbox it is alot of prop i can only pitch it to a medium setting to get good rpm but does this thing pushhhhhhhhhhhhhhhh!it will start to break ground and move at 2100 engine rpm and will launch of the ground if i floor it.i do not think it is all that quiet but i have not been on the water with it yet.i am only posting this info on the site just in case someone else is planning on trying this and they can refferance this thread.if anyone has a specific question i will try and answer.but my opinion is 2.38 or bigger is needed unless you dont won't to change a whole set up.when i get a chance to hit the water i will add more to the post.
