Doodle Bug
Posted: Fri Dec 14, 2007 8:55 am Post subject:
One of the best ways to make your exhaust quieter is to add at least 30 inches of
pipe behind your mufflers. Adding suppertraps to mufflers can cause too much
back pressure. GM recommends not to exceed 2 inches of back pressure. Our
cross-under exhaust using a resonator with a twisted baffle under the engine and
mufflers mounted to the transom only produced 1 inch of back pressure. A back
pressure tester can be purchased from most local auto parts stores. probably
under $ 100.00. Mine is made by Star Products, part # TU-24A Three Way Exhaust
Back Pressure Tester. It is a must if you are going to design an exhaust system.
With the suppertraps, you will probably have to add plates until the back pressure
drops just below 2 inches. I have never tested suppertraps. CHUCK
I’ve always wanted to know how to check my muffler systems to see if it is hurting my performance. After reading Chuck’s information, I now have a new question. I do not want to buy a back pressure tester (BPS) because I will be only be using it one time.
I was thinking if I removed my mufflers at the inlet for a short time; would I hurt my engine? I remember someone telling me the cold air would warp my valves.
What is the best way to test a muffler system on a Chevy 350 S.B., with 2- Flowmaster 3” inlet, dual 2” outlet muffler?
Would I be better off buying new mufflers, if so, which ones?
