testing posting pic
emmitt Kelly
those that are interested: the 3 blade Aero Products were the first Props used on C-130's
when the "B" model and on to the "H" model used Hamilton Standard.
One of the engine builders
on this site talked about 'Harmonics".. that was an understatement.
when you have more than one prop, a vibration develops..Prop sync comes into play. and Aero Products
just could not get it together.
I have been told the C-133 was worse, you could stand in the cargo compt. and you will vibrate off the plane of rotation.
the c-133 also began to fall out of the sky due to internal failure in the wings and wing box.
PeaRiverOpossum
The "easiest" way that I have found to post pics on here is to open a http://www.photobucket.com account (free) and upload as many pics as you want then copy the IMG code and paste it in your post. They will appear like this:
PeaRiverOpossum
And if you dont want them to be HUGE like this one, you can use Light Image resizer 4 (free)to make them smaller.
emmitt Kelly
Great pics!!
My problem was I was trying to use a MacBook...they go about things a little different
however, Rick came through his instructions got me on track ..
thanks for the help..emmitt
